Author Topic: Cannot access websites  (Read 12270 times)
Online Clive
« on: November 09, 2002, 13:09 »
For some reason I can no longer access certain Yahoo websites which are on my favourites list.  Most of Yahoo is readily available, but I am getting "Page not Found" on the ones I really need.
Re:Cannot access websites
« Reply #1 on: November 09, 2002, 14:17 »
I always give in to temptation to start fiddling with things if I can't get a web page, but 99% of the time, it's just a temporary fault with the website, so I'm slowly learning to leave well alone and try again later.
Perhaps the pages have moved, Clive?  Maybe you could find them via the Yahoo menus?
Online Clive
« Reply #2 on: November 09, 2002, 14:32 »
I know that the websites are there as I just went up to my local library. I came back and I can't access them via the Yahoo menus either.  It's the same with both machines on my network.  Weird or what?
« Reply #3 on: November 09, 2002, 14:53 »
Clive do you want to post the URL of the site/s you are trying to access (unless theyre porn ones of course)  ;)
So we can see if we can get them ok  :-*
Online Clive
« Reply #4 on: November 09, 2002, 14:56 »
This long URL
or: http://dir.yahoo.com/Science/Astronomy/     then the link Astronomy and Space News at the top
* Adept fixed the URL so that it doesn't break the page formatting ;)
« Reply #5 on: November 09, 2002, 15:00 »
It looks like the site is down Clive as it doesnt work for me either  :-*
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Just as I was hoping for some juicy stuff too  ;)
Second one works but not the link from it Clive  :-*
Online Clive
« Reply #6 on: November 09, 2002, 15:02 »
I am getting closer to the problem.    I just tried it using a 56K modem and it works perfectly ok.  It just wont work with ADSL.  How can that be?
« Reply #7 on: November 09, 2002, 15:06 »
Maybe a routing problem Clive but I would have thought whether on ADSL or on dial up it would tie up with the same servers at some point  ???
Maybe the plebs on 56K have found a way to put a spanner in the works for the lucky few of us on BB  ;)
Online Clive
« Reply #8 on: November 09, 2002, 15:09 »
Yes, I forgot you are on broadband too.   ;D  This is becoming very curious isn't it?
« Reply #9 on: November 09, 2002, 15:20 »
To quote alice in wonderland " Curiouser and curiouser "
Can you access them ok Simon?
« Reply #10 on: November 09, 2002, 15:26 »
The second one, yes, and the link to the Newsey bit, but the first one I just get "The requested URL /search/diy/fc/astronomy/ was not found on this server."  That would indicate to me that it's been removed.
Online Clive
« Reply #11 on: November 09, 2002, 15:35 »
Maybe the first url was just the result of a "not found" page so we should ignore that one.  I wonder if it's anything to do with the firewall built into the router?
I couldn't access Yahoo Messemger either until I changed the preferences to "Firewall No proxies"
« Reply #12 on: November 09, 2002, 15:38 »
I think The Saint is the one to call on here, Clive!   ;D
Online Clive
« Reply #13 on: November 09, 2002, 15:57 »
Yes, it must be a setting needs changing although even that doesn't make any sense to me!  ;D
« Reply #14 on: November 09, 2002, 16:07 »
Any chance of editing that post above, Clive, to get this page back to it's normal size?   :)
