Author Topic: ram upgrade query  (Read 1526 times)
Offline stefos
ram upgrade query
« on: May 12, 2006, 13:49 »
Hi, My motherboard (VL400) will only take up to 512mb ram. What will happen if I should add 256mb to it? I mainly need  it for speech recognition as 'upping' the ram would make dictation more fluid.
Otherwise what would be the most sensible option do you think?
Regards
Stefos
p.s. I am sure I posted this question correctly a short while ago but it never materialised, so my apologise if it gets duplicated!
ram upgrade query
« Reply #1 on: May 12, 2006, 13:59 »
So the maximum you can have in your motherboard is 512mb? How much do you currently have in it?
Offline stefos
ram upgrade query
« Reply #2 on: May 12, 2006, 14:27 »
I have 2* 256mb in the two only slots but I have a 512mb card available
Stefos
ram upgrade query
« Reply #3 on: May 12, 2006, 14:36 »
ok, so each slot can take a max of 512? I think you will be suprised of the increase you will get, though make sure you have the right ram before you stick it in!   :)
Offline stefos
ram upgrade query
« Reply #4 on: May 12, 2006, 15:23 »
No Sam, the max the board will take (HP VL400) is 512 mb!
I currently have 2*256mbs, do you reckon I could get away with 1*256 and 1*512mb without any harm?
ram upgrade query
« Reply #5 on: May 12, 2006, 20:47 »
It shouldnt do any harm its just that the bios may not recognise the ram above a total of 512mb.
Try it with just the single 512mb in and if it boots ok and recognises it as 512 then add a stick of 256 and see if it still boots ok and recognises the full size.
You could check the manufacturers site to see if theres a bios upgrade available that may raise the ram limit as I think that the maximum ram is goverened by the bios.
Offline stefos
ram upgrade query
« Reply #6 on: May 13, 2006, 13:57 »
Thanks Sandra,I would have liked to have said it worked fine but have now realised I bought the wrong one!
What a pillock!
?HP Server SDRAM 512mb pc133 ECC Reg Dimm 168 pin? ? everything correct except the bloomin? ?Server?, -not compatable.
Must pay even closer attention next time... Grrr!
Regards :blush:
Stefos
ram upgrade query
« Reply #7 on: May 13, 2006, 14:14 »
www.crucial.com/uk guarantee memory compatability, or they refund you (providing you have given the correct information in the first place), so might be worth giving them a try.
