April 19, 2025, 13:21
Technical Help & Discussion
Macromedia Flash
Topic: Macromedia Flash (Read 1085 times)
GillE
Never totally serious
Macromedia Flash
May 18, 2006, 20:51 »
Is it possible to save Macromedia Flash broadcasts off the internet?
(Schopenhauer,
Die Kunst Recht zu Behalten
Macromedia Flash
May 18, 2006, 22:18 »
Is
this
the sort of thing you're looking for, Gill? Unfortunately, all the ones I have found only work with IE, and are also all shareware, but if you just want something for one job, a trial version might do the trick.
GillE
Macromedia Flash
May 19, 2006, 01:13 »
That's just the job, Simon - thanks
. Let's hope the 'nag' screen isn't too obtrusive.
Gill
(as tight with the purse strings as ever!)
(Schopenhauer,
GillE
Macromedia Flash
May 19, 2006, 01:56 »
Having just installed the software, my firewall's asking me if I want to allow it to access the following website:
http://www.boreme.com//boreme/funny-2006/SexChange-p1.php
:shock:
I think I'll uninstall it quickly and run anti-malware checks in the morning.
Gill
(Schopenhauer,
Macromedia Flash
May 19, 2006, 09:46 »
That's very surprising, Gill. Usually the stuff from Download.com is very safe. There are, of course, other softwares available which do the same thing. Take your pick from
here
Macromedia Flash
