April 16, 2025, 23:06
Technical Help & Discussion
wma into mpg3
Topic: wma into mpg3 (Read 2660 times)
wma into mpg3
May 21, 2006, 11:58 »
I have recently acquired some audio files that I'll be burning to CD and a couple of them are wma files. I've googled it and I see there are wma to mpg3 converters.
Can someone suggest one that would be the best to use. And of course easiest. :?
wma into mpg3
May 21, 2006, 12:06 »
this one
LINK
is pretty simple, though there appears to be some loss between wma to mp3 conversion, but it is hardly noticeable. It is also a nice a easy program to use.
wma into mpg3
May 21, 2006, 12:26 »
Thanks Sam worked a treat. :wink:
wma into mpg3
May 21, 2006, 12:39 »
wicked.
wma into mpg3
May 21, 2006, 13:27 »
Seeming that was so successful thought we'd try video conversion.
Michael needs a mpeg to avi converter.
I found one that was the other way around, wasn't sure if it would do the reverse.
wma into mpg3
May 21, 2006, 13:34 »
this is a rather basic tool and im not sure out the output, it might be pretty huge... have a play:
http://home.cogeco.ca/~avi2vcd/
wma into mpg3
oh i just gave u the other way around!
wma into mpg3
May 21, 2006, 13:37 »
you may want to try...
http://www.divx-digest.com/software/exstream.html
... pretty simple but I'm not sure that you will not get a huge file.
wma into mpg3
May 21, 2006, 13:41 »
Thanks Sam just had a look, is it also compatible with xp.
wma into mpg3
Reply #9 on:
May 21, 2006, 13:45 »
i know, i keep finding xp solutions...argh, if you wanted linux... lol
wma into mpg3
Reply #10 on:
May 21, 2006, 14:00 »
Is this one any good.
http://www.freedownloadscenter.com/Utilities/Text_Editors_A-G/SC_Free_Video_Converter.html
wma into mpg3
Reply #11 on:
May 21, 2006, 15:19 »
sounds from the description like it will work but I'm not sure I'd trust that software, seems a bit dodgy, like it might contain malware.. give it a scan and a go...
Sandra
Ultimate Member
wma into mpg3
Reply #12 on:
May 21, 2006, 20:37 »
WinAvi is about the simplest one MB, not free but well worth the money I think
Check your email :wink:
wma into mpg3
