Author Topic: upload SWF Avatar  (Read 3125 times)
Offline GSS
    • artzone4u.com
upload SWF Avatar
« on: May 22, 2006, 17:59 »
can we have it so we can have it so we can upload Avatar in SWF
has i made one i like to use but it need to be SWF to work
you can see it here it called  ahw.swf
http://s82.photobucket.com/albums/j274/realhitman/?action=view&current=ahw.swf
 :dunno:
www.artzone4u.com
banner coming soon
upload SWF Avatar
« Reply #1 on: May 22, 2006, 18:30 »
Usually we can, and we did, but there's a problem with the forum software, which means we can't at the moment.  That's why I changed mine from SWF to GIF.
Offline GSS
    • artzone4u.com
upload SWF Avatar
« Reply #2 on: May 22, 2006, 18:32 »
i see do you know then it will be back up
www.artzone4u.com
banner coming soon
upload SWF Avatar
« Reply #3 on: May 22, 2006, 19:23 »
Hopefully when the next PhpBB update appears, but we don't know when that will be.
upload SWF Avatar
« Reply #4 on: May 22, 2006, 21:04 »
or when i fix the issue..... which isnt likely to be soon!! :(
upload SWF Avatar
« Reply #5 on: May 22, 2006, 22:37 »
is swf file uploading isn't working how is it I can see mine.??
upload SWF Avatar
« Reply #6 on: May 22, 2006, 23:25 »
It's because you haven't changed yours since the last forum software upgrade, Lona.  Existing HTML (the code you have to use for your sig) seems to be OK, but any new or amended HTML doesn't seem to work at the moment.  Best advice is to leave it alone.  :)
Offline GSS
    • artzone4u.com
upload SWF Avatar
« Reply #7 on: May 23, 2006, 08:47 »
so if i go back in time i can put it in  :lol: ok thank you for the help  :D
www.artzone4u.com
banner coming soon
