July 05, 2024, 12:07
Technical Help & Discussion
how to disable memory/video share
Topic: how to disable memory/video share (Read 1352 times)
roaddogg
New Member
February 09, 2003, 00:55 »
hi everyone
i noticed that my videocard is integrated,and taking up my memory space,is there anyway i can disable it from taking space,i installed the new card,but my ram still reads 192 mb,instead of 256,
Sandra
Ultimate Member
Re:how to disable memory/video share
February 09, 2003, 01:29 »
Did you disable the on board graphics in your BIOS when you installed the new graphics card?
Without going back and checking your previous posts I cant recall which OS and PC you are using
bat69
Loyal Member
February 09, 2003, 01:43 »
there may be a jumper on the mobo to disable the onboard graphics ... and as Sandra has mentioned ... try the BIOS
roaddogg
New Member
February 10, 2003, 00:33 »
i tried in the bios
everything looks to scary for me
i tried disabling it in system properties
didnt work
it wont boot with my gefore video card
i have windows xp
Sandra
Ultimate Member
February 10, 2003, 00:38 »
Can you tell me which Bios it is ( Award,Amibios or Phoenix). Then I have a chance at telling you where to look and hopefully what to set it to
