Author Topic: add a song to a banner  (Read 1571 times)
Offline GSS
    • artzone4u.com
« on: June 10, 2006, 11:23 »
ok do not know if i put is in the right put but any
can some one tell me how i can \and add a
"start" and "stop" button on it to play and stop the song
i just can't find the way
www.artzone4u.com
banner coming soon
« Reply #1 on: June 10, 2006, 11:34 »
I don't think you can, GSS, not to a GIF image.
Offline GSS
    • artzone4u.com
« Reply #2 on: June 10, 2006, 13:04 »
i what to add it to a swf
www.artzone4u.com
banner coming soon
« Reply #3 on: June 10, 2006, 13:10 »
Depending which program you are using you usually have to add a button and then select what you want to happen on which action.
You can have it start music on roll on and stop on roll off or start on click etc.
You can also have the button make it go to a different scene or an url.
Offline GSS
    • artzone4u.com
« Reply #4 on: June 10, 2006, 15:22 »
ok what would me the best program at will let me add buttons one at you click on to start the song and one to stop the song
www.artzone4u.com
banner coming soon
« Reply #5 on: June 10, 2006, 15:40 »
You can download a 15 day trial version of SwishMax from here.  I prefer the older Swish2 myself, but it seems to have been discontinued, although you may still find a version of it somewhere.
Offline GSS
    • artzone4u.com
« Reply #6 on: June 10, 2006, 15:52 »
ok if you can please it be a help
has the link i give me then i put my email in it comes up
Sorry, there seems to be a problem.
If you were unable to obtain a trial key and have not previously trialed the product, please contact Support.
It is also possible that you are not entitled to a further trial for this product or the product does not support trial licenses.
You can purchase an unlimited license here.
If you have already purchased a license, enter your registered email address below, with the completed Site Code, and press 'Go!'.()
www.artzone4u.com
banner coming soon
