Never used McAfee myself. Heard it's a bit of a system hog, but let us know how you get on. Has the removal of Norton had any positive effects on performance?
Hi Simon. Removal of Norton was to serve as sort of un-doing the chains (so to speak) from AOL. It seemed like Norton was conflicting with AOL and AOL technical agreed. They helped me try to configure Norton but to no avail then AOL itself actually said 'Norton firewall detected, causing AOL connection problems' so I though, enough is enough, Norton must go!! McAfee seems ok so far fingers crossed.
I have come across another problem, only since I installed some RAM a few weeks ago, it's happened twice now, I got the blue screen of death and instead of the driver problem, I got this code:
STOP : 0X0000007E (0XC0000005,0XB8D2A7E6,0XBA7DF9IC,0XBA7DF618)
psa906.sys-Address B8D2A7E6 base at B8D26000,Datestamp 40aba21b
When I sent the error report to Microsoft, the message said :Error reading random access memory.
I have run the Windows RAM test and the first series of tests where it tests with cache on, all come back fine, it then started to test un-cached and took over 10 minutes just to finished test 1 with another 5 to go, I didn't have time to finishe the test but so far all seemed ok. I did the test with both sticks in, should I test them seperatley to get a more accurate test? and what if the test comes back clean? where else can I look?
Just for the record, I was getting the BSOD before I fitted the RAM but as already mentioned, the error message was Driver IRQL not less than or equal to. Now I am getting two BSOD errors and am starting to pull my hair out! What started as what I thought was a simple overheating and AOL/norton conflict, seems to be taking on a more sinister form. I'm not even sure what is what anymore!
![Cry :cry:](http://www.pc-pals.com/smf/Smileys/Smileys/cry.gif)
HELP!!!! before I lose ALL my hair!!
I will try anything as long as it doesn't cost a lot. I've spent money on RAM, CPU cooler, 2xfans in the last month and the wife is gonna kill me if I spend much more! Any help leading to a result, and I'll buy all the drinks in the virtual pub all night!
Many thanks in advance (hopefully!)
Regards
Mike
