Author Topic: Situational Awareness Scenario.  (Read 881 times)
« on: June 26, 2006, 12:35 »
Situational Awareness Scenario:
You are driving in a car at a constant speed.
On your left side is a valley and on your right side is a fire engine traveling at the same speed as you.
In front of you is a galloping pig which is the same size as your car and you cannot overtake it.
Behind you is a helicopter flying at ground level.
Both the giant pig and the helicopter are also traveling at the same speed as you.
What must you do to safely get out of this highly dangerous situation?
Answer:
Get off the children's "Merry-Go-Round", you're p**sed.
« Reply #1 on: June 26, 2006, 13:04 »
:pmsl:   What took them so long to think that one up?  It's pure genius!
