July 05, 2024, 11:39
Technical Help & Discussion
H/D grinding after reboot !!
Topic: H/D grinding after reboot !! (Read 1664 times)
TOFFEEMAN1878
Regular Member
August 07, 2006, 12:32 »
Settled down after several reboot attemps including getting a message to insert system disk ,any clues to what could be wrong ??...Jim
August 07, 2006, 12:37 »
My immediate guess is that the hard drive is on the way out - suggest you start backing up any valuable data while you still can. :|
TOFFEEMAN1878
Regular Member
August 07, 2006, 12:39 »
It's less than a year old Simon :evil:
Sandra
Ultimate Member
August 07, 2006, 12:53 »
Hard drives can fail well inside their warranty period Jim.
I like Western Digital drives as I have found them to be the most reliable.
I had a WD 250 gig 16mb SATA 2 drive fail earlier this year that came with a 3 year warranty yet it failed within 3 months :shock:
TOFFEEMAN1878
Regular Member
August 07, 2006, 13:03 »
Boo whoo whoo ,looks like I have some serious backing up to do !!
August 07, 2006, 13:26 »
I had one fail after just 4 weeks!
August 07, 2006, 13:54 »
Sorry it's bad news, Jim. At least, if it's less than a year old, you should be able to get a replacement under warranty.
gmax
Established Member
August 07, 2006, 15:19 »
I like Western Digital drives as I have found them to be the most reliable and
maxtor the worst, but dont waste a dead harddrive pull it apart and get the
magnet out, their a real strong magnet
TOFFEEMAN1878
Regular Member
August 07, 2006, 18:22 »
Thanks for the replies guys& girls , it's a WD 80GB with only 23% used shouldn't take too long to transfer all the data !!
Thanks again ....Jim
