Author Topic: system 32 screen  (Read 951 times)
Offline spooner
system 32 screen
« on: August 07, 2006, 15:16 »
hi,
for some reason every time i boot up, i get a screen saying system 32 with loads of folders in it, i close it and my pc works fine, it`s not a problem just a bit annoying, it`s never happened in the past.
Does anybody know how i could stop it happening ?
cheers
sed all my sick, t`morra i`m ringing in dead !
system 32 screen
« Reply #1 on: August 07, 2006, 18:27 »
This appears to be a known problem, and there's a Microsoft article about it, including a remedy, here:-
http://support.microsoft.com/?kbid=170086
Hope that helps.  :)
P.S.  This could also be the symptom of a virus, or some other malware, so you might want to make sure your anti-virus software is fully up to date, and run a full system scan.
