Author Topic: Netgear DG824M Installation CD  (Read 1529 times)
Offline DJ
« on: August 26, 2006, 16:01 »
Hi All,
I have decieded to reinstall windows on my PC, but before I do so I have checked that I'll have all the installation CD's needed after I do.
One I have missing is the installation CD for my Netgear DG824M wirelss router and modem (quite a critical one). I can't seem to find it anywhere.
Does anyone know of a site where I can download the files needed for installation.
Cheers
DJ
Offline gmax
« Reply #1 on: August 26, 2006, 16:18 »
Offline DJ
« Reply #2 on: August 26, 2006, 16:30 »
Thanks for that.
I'm now thinking that I don't need a CD. Just connect it, use DHCP and type in the IP address.
Hope that'll work - there's no going back now!
DJ
« Reply #3 on: August 26, 2006, 17:21 »
Good luck DJ!  Hope to see you on the other side!  :D
« Reply #4 on: August 26, 2006, 18:00 »
You dont need to touch the router DJ, unless it has a print server part.
The router is independant of the pc/s that it is attached to and all the information regarding your internet connection will still be in it unless you reset it  :)
Offline DJ
« Reply #5 on: August 27, 2006, 16:46 »
Thanks for that Sandra.  You were (of course!) correct.  I didn't need to touch the router.
The PC is now back up and running much much faster after its Bank Holiday clear out.
DJ
