July 05, 2024, 09:10
Technical Help & Discussion
Find a routers login and password
Topic: Find a routers login and password (Read 2317 times)
September 16, 2006, 10:52 »
Ever needed to know the default username and password for someone's router? no fear, here is a big list of lots of them...
http://www.phenoelit.de/dpl/dpl.html
Deborah Marcotte
New Registration
Re: Find a routers login and password
August 07, 2007, 05:23 »
Thanks...Needed that list just yesterday..
Reno
Established Member
ø¤º° bob °º¤ø
August 07, 2007, 06:22 »
Useful, great for those pesky routers without a decent company support page.
Kaz
Full Member
Im getting There Slowly But Surely
August 15, 2007, 20:21 »
So what you are saying is if you need to get into a router you can use one of these, so if I wanted to get into soemone eles router and new thwe make and model I could use one of these names and passwords?
Baz
Established Member
August 15, 2007, 21:37 »
thats it I believe............unless they have changed the username and password, which is usually recommended by the manufactures anyway.
August 15, 2007, 22:36 »
Yes, those are just the default settings. The passwords would usually be reset by the user, so unless the password is known, access wouldn't be possible without resetting the router to factory defaults.
August 16, 2007, 01:23 »
which can be damn useful when friends have forgotten their settings
Kaz
Full Member
August 16, 2007, 12:00 »
Oh that's ok then I had visions of someone sitting out side my house trying to connect to my router
Im glad mine is protected and security pasworded aswell
