Author Topic: Difficulty Removing SonicStage Software  (Read 1284 times)
Offline Jaminxz
« on: September 21, 2006, 10:49 »
I've had a bit of a nightmare with my sony mp3 player, or rather the pc software,sonic stage. Its a long story but the jist is it went haywire, wouldn't start properly, kept closing it's self down and so on, not sure if it was a virus or just poor software. Anywho It won't remove it's self the normal way (in add/remove programs) so i've (probably a bit foolishly so) started to do it manually, by messing around with regedit, even tho i don't know what i'm doing and i'm in a bit of a mess I searched thru the registries and thought i'd deleted everything sony, but it's folders are still in the program files along with a few dll files and i don't think it;s properly gone. I was wondering if there is any software that could help me with this, i.e do it for me or if anyone has any advice on how to get rid of it properly??
thanks in advance,
Jaminxz
« Reply #1 on: September 21, 2006, 15:22 »
I use a program called Your Uninstaller.
Its a pay for one bit is available free if you look in the right places  :wink:
Offline gmax
« Reply #2 on: September 21, 2006, 15:29 »
If your using XP try using" system Restore" restore your pc to a time before you installed "sonic stage".
Offline Jaminxz
« Reply #3 on: September 22, 2006, 03:03 »
Yo gmax, i did try the system restore but it had no effect.I tried everything! now am going to try sandra's approach!
Offline Jaminxz
« Reply #4 on: September 22, 2006, 15:42 »
Your uninstaller, what a program!!!
thanks alot sandra, this fixed everything! was able to uninstall sonic stage then install the new software and now my mp3 player is up and runing!!
thanks
Jaminxz
« Reply #5 on: September 23, 2006, 01:08 »
Theres not much it hasnt removed and cleaned up when I have used it.
Pleased it worked for you  :)
Offline gmax
« Reply #6 on: September 26, 2006, 06:17 »
Ive just downloaded "Your Uninstaller" and tried it, it works very well,thanks for the info sandra :)
