Author Topic: what pc should i get??please help??  (Read 1158 times)
Offline princesslozlina
  • New Registration
« on: October 14, 2006, 22:34 »
hello....
can anyboby help me, i am in desperate need to find a computer or laptop asap, the onlly prob is i have no idea what type i should be getting!! I am a student studying textiles design, and for part of my course i need a good computer/laptop that is good for art and design purposes. I really wanted a laptop so i can take it around with me, but a friend told me they dont tend to have very much memory??
I would really really appriciate it if someone has any advice....
Thankyou...lorna x
« Reply #1 on: October 14, 2006, 22:44 »
If you're looking for a very reasonably priced PC you could look here
http://www.ebuyer.com/UK/store/26/cat/Home-PCs  OR
for laptop try this..................
http://www.ebuyer.com/UK/store/45/cat/Notebooks/Laptops
« Reply #2 on: October 14, 2006, 23:16 »
Hi Lorna, can you give us an idea of what you would like to spend?
Offline Camstop
« Reply #3 on: October 14, 2006, 23:17 »
I'd go for one of these depending on your budget...
http://www.dmxdimension.com/blogcategory/dell_uk_dimension_3100.html
To get the price stated you need to click the link of the one you fancy then click on the "support services" icon and select collect and return 1 year to give you the price shown on the first link.
The main difference in them is the size of the monitor.
 :welcome:
« Reply #4 on: October 15, 2006, 17:22 »
How much money are you prepared to devote to the laptop?
