July 05, 2024, 11:55
Technical Help & Discussion
Web cam not working
Topic: Web cam not working (Read 903 times)
JK
Regular Member
Web cam not working
October 25, 2006, 21:52 »
Hi
Think this problem should be posted under software?
I have a webcam that will not work with Yahoo messenger. It locks the pc up when it tries to open. The webcam works fine in other(non messeger) applications.
Kind regards.
Web cam not working
October 26, 2006, 07:30 »
Have you checked out the Yahoo messenger troubleshooter JK? Here is the bit about webcams.
http://help.yahoo.com/help/us/messenger/win/webcam/
JK
Regular Member
Thanks Clive
October 27, 2006, 20:48 »
I followed your link and ended using regedit to fix the problem.
Thank you.
Web cam not working
