Author Topic: Flash Sigs  (Read 5036 times)
Flash Sigs
« on: November 05, 2006, 14:30 »
Could those with Flash Sigs please go into your profile and edit them, so that the following code is used?  Adjust the size accordingly.
Code: [Select]
[flash=500,100]url[/flash]
At the moment, there are bits of HTML appearing in the sigs, and we don't want our new home to look untidy!   ;)
Re: Flash Sigs
« Reply #1 on: November 05, 2006, 14:42 »
Changed to setting you gave Simon and you can see the results.  ;D
Are you sure those are the correct settings.
Re: Flash Sigs
« Reply #2 on: November 05, 2006, 14:45 »
Code: [Select]
Sorted.
Re: Flash Sigs
« Reply #3 on: November 05, 2006, 14:45 »
fixed it for ya lona... you had an extra " in there somehow... probably from copying the uri.
Offline GSS
    • artzone4u.com
Re: Flash Sigs
« Reply #4 on: May 03, 2008, 08:12 »
ok i had a look in my sig and at the html i got  :) so at will save me so time
www.artzone4u.com
banner coming soon
Re: Flash Sigs
« Reply #5 on: May 06, 2008, 08:37 »
You can also use this to block them all.  ;D
Re: Flash Sigs
« Reply #6 on: May 06, 2008, 09:04 »
or just disable signatures in your profile on here.
Re: Flash Sigs
« Reply #7 on: May 06, 2008, 09:56 »
Do you get a blue badge that way, Sam? ;)
Re: Flash Sigs
« Reply #8 on: May 06, 2008, 09:57 »
Re: Flash Sigs
« Reply #9 on: May 07, 2008, 09:27 »
yep.
Re: Flash Sigs
« Reply #10 on: May 07, 2008, 15:11 »
Spoilsport   ;D ;D ;D
