Author Topic: IE7 will download tonight  (Read 1310 times)
« on: November 14, 2006, 22:28 »
Or not.  It failed on mine, producing a ton of errors.  Files could not be copied files could not be deleted etc etc.  Anyway, IE7 is not compatible with my computer.  Tough huh?   ;D
Re: IE7 will download tonight
« Reply #1 on: November 14, 2006, 22:39 »
But how much damage has it done, and crap has it left behind?   :crazy:
We could be busy tomorrow!   >:-)
« Reply #2 on: November 15, 2006, 07:41 »
Probably all my antivirus software just doing its job!  ;D  To be fair, it fully restores your computer to what it was before it became infected.
« Reply #3 on: November 15, 2006, 08:58 »
I've just downloaded and installed it onto Mrs Clive's computer which is identical to mine.  No problems at all!   :dunno:
« Reply #4 on: November 15, 2006, 09:29 »
obviously you haven't got that antispyware to the appropriate level on hers to stop microsoft re-infecting it!
« Reply #5 on: November 15, 2006, 09:57 »
The message on mine says:
CAUSE
? Something has caused the computer not to trust the Internet Explorer 7 installation package.
« Reply #6 on: November 15, 2006, 10:52 »
I installed it and used it a few times, but not anymore.
When I was researching memory for Michaels computer I had about 6 tabs open with various sites that had taken me all afternoon to find and up pops a message stating that something had gone wrong with IE7 and it had to close. This happened twice, so no more, it's had it's second chance.
But I do like WMP 11.
