Author Topic: F.E.A.R. Extraction Point  (Read 3110 times)
Offline gmax
« on: December 03, 2006, 13:13 »
anyone played "F.E.A.R. Extraction Point" ? nice looking game but my pc struggles to
play it at 1024x768 :( , it must be time for an upgrade :)
Re: F.E.A.R. Extraction Point
« Reply #1 on: December 12, 2006, 10:29 »
Michael has F.E.A.R. but not this one.
Games are becoming more demanding, that's why I'm upgrading Michaels.
« Reply #2 on: December 12, 2006, 10:38 »
nothing new to that MB, they always have and always will....
« Reply #3 on: December 12, 2006, 10:44 »
I used to play games on the Atari then we got the Sega, but when he moved on to the Nintendo, that was me done.
Now I just pay for them.
« Reply #4 on: January 23, 2007, 12:10 »
I bought Extraction Point for Michael a couple of weeks ago, and he has only now been able to play it. I bought the original F.E.A.R from a seller in Thailand on eBay, not knowing that asian version is different from the US/UK versions. Michael needed a patch for it before he could install the extension, took ages but a friend found it and downloaded it. Now I know why the Asian versions are so cheap.
Anyway he turned the graphics to max and he loves it.
« Reply #5 on: January 23, 2007, 17:11 »
 :D
Offline gmax
« Reply #6 on: February 10, 2007, 12:49 »
You also need the patch for US/UK versions also, Fear has to be updated to version 1.06 before you can install "Extraction Point" i think it was about 200 MB download! on
dial up that is a real pain. :(
« Reply #7 on: February 10, 2007, 13:09 »
But if you purchased "Extraction Point", it has the patch on it, unfortunately it didn't help us.
I don't think I could cope with dial-up.
Offline gmax
« Reply #8 on: February 10, 2007, 13:22 »
I hired "extraction point" it did not have the patch on it, i had to download it. :(
« Reply #9 on: February 10, 2007, 13:53 »
I didn't know you could hire pc games, I've never looked, but you'd think they would come with the patch....Ahh, OK I see, the patch is so you can install it, of course they wouldn't supply the patch.
I have no idea how pc games work, can you just play them off the cd or do you have to install them on your pc first? ??? :blush:
Offline gmax
« Reply #10 on: February 10, 2007, 14:20 »
Most games you have to install them on your pc first then insert the cd/dvd , but
there are ways around it so you don't have to insert the cd/dvd everytime you want
to play the game ;)
