Author Topic: Gmail.  (Read 2347 times)
Gmail.
« on: December 12, 2006, 11:01 »
I recently installed Gmail, (thanks Sam) but when I click on the little envelope tray icon it opens in IE.
Anyone know how I can get it to open in FF.
Re: Gmail.
« Reply #1 on: December 12, 2006, 11:27 »
little envelope tray? Is this in thunderbird or outlook?
Re: Gmail.
« Reply #2 on: December 12, 2006, 11:36 »
It's Gmail notifier, it's a little white envelope that sits in the tray, and when I click on it to check mail it opens in IE. I don't know how to change it so it uses FF instead.
Re: Gmail.
« Reply #3 on: December 12, 2006, 12:21 »
not sure, i've never used it.... ill try and find it later...
Re: Gmail.
« Reply #4 on: December 12, 2006, 12:43 »
I don't seem to have much luck with email notifiers, but I'm persistent.
http://www.techsupportalert.com/best_46_free_utilities.htm#12
I have to work out how to put my email addresses together and the email notifier so it works through Gmail.
But not now. :snooze:
Re: Gmail.
« Reply #5 on: December 12, 2006, 18:52 »
You can't open mail in Firefox, MB, or in IE come to that.  :-\  Can we assume you mean Thunderbird, which is the accompanying mail client?  If so, try resetting it as your default mail client (Options > General).
Offline Scottytoohotty
Re: Gmail.
« Reply #6 on: December 12, 2006, 21:51 »
it sounds like to me it notifies you when you have mail, and then when you click on it it brings you to the gmail website. the problem is that it is opening in IE instead of Firefox.
I don't use it so i can't help you much except to check and make sure that Firefox is set as your default browser, and then check whatever settings (if any) come with the notifier and see if you can set it there (probably not but worth a look)
Re: Gmail.
« Reply #7 on: December 12, 2006, 22:16 »
Ah yes, you're probably right there, Scotty.  I was working along the lines of downloading mail to an email client via POP3.   :blush:
Re: Gmail.
« Reply #8 on: December 12, 2006, 23:57 »
Thanks Scotty I'll do just that, and btw  :welcome:
Simon I was thinking the same thing.  :blush:
Re: Gmail.
« Reply #9 on: December 14, 2006, 00:43 »
I'll just point out that I always use websites for email instead of email clients. It's easier to access anywhere. They almost all have settings to send the email to another email address so I can access all my mail from 1 email too, so I don't have to worry about using too many emails. Sure, there are alternative ways to get email from anywhere but in my eyes this is the simplest.
of course for business emails, using a standard client is better, but I don't like it much at all for personal use.
Re: Gmail.
« Reply #10 on: December 15, 2006, 00:33 »
That's very interesting Scotty, except how do you use websites?
Re: Gmail.
« Reply #11 on: December 15, 2006, 00:46 »
www.yahoo.com
hit the mail button
Re: Gmail.
« Reply #12 on: December 15, 2006, 01:03 »
Silly me, thanks Scotty.
Re: Gmail.
« Reply #13 on: December 15, 2006, 13:41 »
and u can do the same with gmail...  o:)
Re: Gmail.
« Reply #14 on: December 15, 2006, 23:55 »
Hey, so you can. I thought the Google page looked different, sign in.
Thanks Sam.  :blush:
