Author Topic: Adobe Reader 8 upgrade.  (Read 967 times)
« on: January 03, 2007, 07:24 »
I downloaded Adobe Reader 8 and when I tried to install it, it kept coming up with that it was being used and could I close anything that was using it and try again. I did all that and still it keeps coming up with the same thing. I even restarted the computer and tried again.:dunno:
The only thing that I can think of is that I clicked on the to replace the existing files when I was installing it(I suppose that means 6 & 7 that I had).
I don't know what to do now, has it (8) replaced some of the existing 7, or can I still retrieve it.
I suppose I should have installed 8 separately? :dunno:
Re: Adobe Reader 8 upgrade.
« Reply #1 on: January 03, 2007, 08:06 »
Have you tried uninstalling it and starting again?
« Reply #2 on: January 03, 2007, 08:17 »
No I haven't  :blush:, but I think I'll give it ago.  :crazy:
« Reply #3 on: January 03, 2007, 11:17 »
Yep, that did the trick.  :blush:
Now that I've mastered that I feel so much more confident in installing Michael's new Graphics Card when it arrives in the next 2 days. ;D :o
« Reply #4 on: January 03, 2007, 13:54 »
:scoot:
