Author Topic: torrent  (Read 1540 times)
Offline Michelle
    • Techieminx
torrent
« on: January 09, 2007, 20:12 »
So it seems I do  have a problem lol ....................Just when you think its safe to start downloading........... :bawl:
My torrent thingy isn't downloading its staying at 0 - 3 kbs ........
I've had a look round and I think it might be something to do with this port forwarding and setting up a static ip but I'm not sure and I don't really want to go messing about with the settings in networking again cos I've managed to get it right to network the other computer on the crossover cable.
Or is it that port forwarding only for routers? Or is it something to do with my Cable modem.
Or someone said somewhere bit comet might be better to try.
Any idea's guys and gals?
Re: torrent
« Reply #1 on: January 09, 2007, 20:18 »
It might be worth trying another torrent client, simply for the reason that it will be set up 'as new', so should offer some sort of connection wizard.  Try http://www.utorrent.com/:)
Offline Michelle
    • Techieminx
Re: torrent
« Reply #2 on: January 09, 2007, 20:30 »
Well.........thanks for that Simon its seems to work better, I've only just turned it on and its up to 70 kbs now, what should it be?
Oh when I just click on it again its down to 36 now lol
Re: torrent
« Reply #3 on: January 09, 2007, 20:43 »
It depends on the number of seeds and peers, Michelle, which can alter your donwload rate.
Re: torrent
« Reply #4 on: January 09, 2007, 22:24 »
Yes, it's very variable.  In uTorrent, go to Options > Preferences > BitTorrent, and make sure Protocol Encryption is enabled.  That should bypass any port throttling your ISP may be implimenting, and you should get the fullest speed connection the torrent allows.
Offline Michelle
    • Techieminx
Re: torrent
« Reply #5 on: January 09, 2007, 22:28 »
Ah right, thanks alot, it seems great now!  Glad I didn't go changing all those settings in connections.
Saved by Pals again  :D ;D
