I want to upgrade my machine. Cash wise, I am not ready for going 64bit so I want to do the best I can with Socket A machines.
I am not into graphics design or anythingrequiring specifically advanced systems, I just play games. I only want the power nescesary to tide me through till I have to go 64bit.
I am trying to take all things into account, such as, even if I could afford it, the GeForce 8800 would so not be worth it cos I don't think the rest of the machine would be powerful enough to take full advantage of it's abilities.
With that into account, I ask for opinions on what I should go for to build up the top Socket A system for now.
My Current System:
Gigabyte K7 Triton Series, nForce2 motherboard
Athlon XP 1900+ (also have a Sempron 2400+ and have bought an Athlon XP 2400+ which should be in the post any day)
2Gb DDR400 RAM
nVidia GeForce 5500 128Mb
I think thats all the really important stuff mentioned, I just ask for the thoughts and opinions you all have on this subject.
Most people here have specific preferences, the only real preferences I have are staying with GeForce and nForce. I have had many bad experiences with the alternatives which have led to hundreds of pounds going into their pockets in exchange for technology thats unreliable, faulty, poorly designed and uses a lot more system memory than I am willing to part with for a single piece of hardware.
Anyways, with that all said, in effect what I asked was...
Before 64 bit arose, what were your dream systems? What were you aiming for?
Cheers in advance
