Author Topic: Mhotkey  (Read 2566 times)
Offline Michelle
    • Techieminx
Mhotkey
« on: February 17, 2007, 23:12 »
Hi again,
Another annoying thing that is happening,
My son downloaded a game called GUNZ its good actually lol but when you close the game it brings up an error with MHOTKEY and says it has had to shutdown, (not sure what the codes are now but I'll get them next time) which sometimes freezes the computer. Which calls for a restart.
Why would it do that?
Any ideas please......... thanks again  :)
Re: Mhotkey
« Reply #1 on: February 18, 2007, 23:30 »
If I remember correctly, I went into the command prompt (Start -> Run) then typed msconfig and in the startup options, de-selected the MHotkey.exe from there.
Offline Michelle
    • Techieminx
Re: Mhotkey
« Reply #2 on: February 19, 2007, 00:27 »
thanks for your input lona..........do I not need Mhotkey then? .............. I'm not sure its happened since I mentioned it lol
Re: Mhotkey
« Reply #3 on: February 19, 2007, 00:29 »
dunno Michelle, all I can tell you is I have it not loading at startup
Offline Michelle
    • Techieminx
Re: Mhotkey
« Reply #4 on: February 20, 2007, 00:13 »
Ah right, I guess not then, I thought it was something to do with the hotkeys on the keyboard, not that I use them much.
Thanks for your advice, I'll try that  :)
Offline Michelle
    • Techieminx
Re: Mhotkey
« Reply #5 on: March 28, 2007, 23:42 »
oh sorry this worked by the way but it still really slows down my comp when its shutdown, very odd, but no crashes now thanks lona  ;D
