Author Topic: loading software  (Read 878 times)
Offline bed49
  • New Registration
loading software
« on: February 18, 2007, 11:47 »
help ! how can i load a programme when all i get is an access violation in install exe ???
Offline Michelle
    • Techieminx
Re: loading software
« Reply #1 on: February 18, 2007, 12:16 »
Hi Bed49
What programme is it you are trying to load?  I don't know the answer but I think it might help to find it.
and  :welcome:
Online Simon
« Reply #2 on: February 18, 2007, 12:47 »
Yes, :welcome:  and as Michelle said, it would help if we had some more details about what you are trying to install.
« Reply #3 on: February 18, 2007, 23:20 »
Have you actually installed the programme?
If so, try uninstalling and re-installing.
Make sure you check the programme folder after uninstalling to see that all files have been removed.
