Author Topic: Program opening  (Read 1887 times)
Offline greenking
Program opening
« on: February 22, 2003, 16:05 »
I'm having great difficulty opening several of my programs as my computer cannot find file mfc42.dll
The only way i can open them at the moment is to find this file by searching and then dragging and dropping it into the short cut on desktop.
:brick::eeek::help:
Re:Program opening
« Reply #1 on: February 22, 2003, 16:10 »
It should be in your c\windows\systemfiles Greenking,have you copied it in there? The programs should find it by themselves from there  :-*
Re:Program opening
« Reply #2 on: February 22, 2003, 16:46 »
Hi Greenking, you are now in DLL Hell! ;)
Usually the cause of this problem is a badly behaved program overwriting the mfc42.dll file with a different version. This can cause all sorts of programs to go wrong.
Have you installed a new program recently? It may the culprit.
If you are running Windows 98 the System File Checker program should be able to restore the correct version of the file for you :)
Offline greenking
Re:Program opening
« Reply #3 on: February 22, 2003, 16:47 »
yes its in there but still getting the following error message:
ERROR STARTING PROGRAM
The COMMONUI.DLL file is linked to missing export MFC42.DLL:6569.
then
C:\ProgramFiles\UleadSystems\UleadPhotoExpress3.0SE\Ipe39.exe
A device attached to the ststem is not functioning
Offline greenking
Re:Program opening
« Reply #4 on: February 22, 2003, 18:52 »
Thanks Adept
The system File Checker seems to have done the trick ;D ;D ;D
I didn't even know i had a system checker till now.
:thanks:
Re:Program opening
« Reply #5 on: February 22, 2003, 19:08 »
Good news Greenking ;D
