Author Topic: MP 3/4 problem  (Read 904 times)
Offline jww41005
MP 3/4 problem
« on: March 14, 2007, 10:57 »
Hello,
I'm unable to load my MP3/4 with music or video.
When I connect it to my PC, windows tells me to format it, so I format it. Then when I click on the player icon, I'm told 'again' that I have to format the player. Something isn't working.
Any clues?
John
If it works, don't fix it
Offline Michelle
    • Techieminx
Re: MP 3/4 problem
« Reply #1 on: March 14, 2007, 16:59 »
hi jww
What player is it that you have?
Re: MP 3/4 problem
« Reply #2 on: March 14, 2007, 17:36 »
also how does it connect to the computer, usb?
Offline jww41005
Re: MP 3/4 problem
« Reply #3 on: March 14, 2007, 21:25 »
Dear friends,
Thanks for your replies.
Well, it's working, but not after a fight.
My player was off e-bay, need I say more?
For 23 quid I got what I thought was a 4GB player, but it was hacked. It turned out to be a 2GB. I rekon the fact that it was hacked provoked the problems, I also think I have a port problem, which didn't help.
Anyway, it seemed to fix itself. Now the memory in the player states 2GB instead of 4GB and everything is loading and working fine.
To be quite honest, I'm very pleased it.
If you decide to get one off e-bay, don't buy it off 'ed2city'.
Saludos from sunny Seville
John ;) :D ;D
Re: MP 3/4 problem
« Reply #4 on: March 14, 2007, 23:19 »
glad it works at the least!
