Author Topic: Ten Reasons why you should upgrade to Windows Vista  (Read 717 times)
Re: Ten Reasons why you should upgrade to Windows Vista
« Reply #1 on: April 02, 2007, 23:50 »
I'm sure someone will come up with just as many reasons not to.  ;D
« Reply #2 on: April 03, 2007, 04:06 »
Lmfao, So if you use window blinds, firefox, and a run of the mill antivirus program there's still no reason to change. Playing xbox live doesn't count because it isn't a reason to switch to vista.
That's a horrible set of reasons. The problem is microsoft is trying to glamorize the reinventing of the wheel. Most people just won't bite. It'll be 2 or 3 years before people decide to buy a new computer. By that time vista will be the only choice because microsoft would have bribed all the manufactures to install it stock.
« Last Edit: April 03, 2007, 04:09 by Bobscrachy »
« Reply #3 on: April 03, 2007, 12:49 »
or their new o/s will be out anyway...
