Author Topic: MPEG To DivX Conversion  (Read 1350 times)
« on: April 11, 2007, 12:15 »
Can anyone suggest some freeware to convert MPEG files into DivX format?
Gill
Re: MPEG To DivX Conversion
« Reply #1 on: April 11, 2007, 12:42 »
Virtual Dub will do it providig that you have the Divx codec installed on your pc.
Heres a guide for how to do it :
http://www.videoforums.co.uk/guide-virtualdub-8.htm
« Reply #2 on: April 11, 2007, 14:18 »
Thanks, Sandra, but VirtualDub doesn't seem to like MPEG2 files :( .
Gill
« Reply #3 on: April 11, 2007, 16:00 »
Have you tried one of its variants like NanDub or Virtual DubMod ?
Gordian Knot and Auto Gordian Knot I am sure will do mpeg2 to DivX or Xvid, the auto one is easier I think and both are free.
« Reply #4 on: April 11, 2007, 18:05 »
Hi Sandra
I've installed AVI.net which seems to be doing the business, albeit slowly.
Tried Auto Gordian Knot but it wouldn't work unless I was online, which I thought was a bit fishy.
Gill
« Reply #5 on: April 11, 2007, 23:59 »
Not known it to only work online before but seeing as my pc is always online if its switched on then I wouldnt have noticed  :dunno:
« Reply #6 on: April 12, 2007, 02:00 »
It could be that it was checking for updates, Sandra.
I've got to say I like AVI.net.  It's producing very good quality videos and you can set a target file size before you start converting.  It's a pity it's rather slow and you can't edit the movie, but those are minor quibbles when you think that you can get a 64 minute recording crammed into 550 Mb and still be perfectly watchable.
Gill
« Reply #7 on: April 12, 2007, 02:03 »
Yes mpeg4 is a very acceptable format as long as you dont overcompress it.
I thought that you had WinAvi already though, thats about the fastest converter.
« Reply #8 on: April 13, 2007, 00:44 »
I thought I had WinAvi... I used to have it...
There again, I used to be able to post on this forum.
Oh look - success this time round  ;D !  Thanks Sandra  ;) .
Gill
