Author Topic: Saving Streaming Downloads from sites such as You Tube  (Read 2070 times)
I havent tried it yet but this program looks like it may be quite useful and its a freebie  :)
YouTube Downloader 2.11
http://www.download3000.com/download_19063.html
Up til now I have been using www.keepvid.com to save clips but they only save as .flv files and you need a suitable player and/or convertor.
If this program works ok then that should be easier and more useful but maybe it wont save from as many different sites as Keepvid will.
« Last Edit: April 12, 2007, 13:53 by Sandra »
Re: Saving Streaming Downloads from sites such as You Tube
« Reply #1 on: April 12, 2007, 15:37 »
I'd be interested to hear how you get on with it, Sandra.  I currently use the Media Pirate add-on with my Firefox browser, but it only saves in .flv format.  I doubt the quality of the video will improve simply by saving them in a different format (much will depend on the original format, of course) but it'll be interesting to compare them.
Gill
Offline DJ
« Reply #2 on: April 12, 2007, 19:45 »
I have used greasemonkey before (Firefox add-in), but then you have to convert the flv file.
Another alternative is http://www.videodl.org/ again downloads flv files.
DJ
Offline sweetbabe
« Reply #3 on: November 01, 2007, 11:31 »
Sandra what converter do you use to convert .flv files? I have Rad Tools that don't seem to do it, SmartSoft Video Converter Pro, Nero 7 and a couple of others.
« Reply #4 on: November 01, 2007, 12:06 »
Total Video Converter does FLV quite quickly along with converting from and to lots of other formats.
« Reply #5 on: November 01, 2007, 16:59 »
RivaFLVencoder is freeware and will convert to and from FLV.
Offline Softix
« Reply #6 on: December 15, 2007, 16:34 »
I was also using Keepvid.com for downloading videos from Youtube and other video sites, but thanks for sharing this software. I like them when they are free to use!
