Author Topic: ImpulseTracker Files  (Read 1074 times)
« on: May 01, 2007, 00:55 »
Does anyone know where i would find an ImpulseTracker to mp3 or ogg converter? This impulse tracker is old as the hills, but i got a ton IT files that i would like to host.
Re: ImpulseTracker Files
« Reply #1 on: May 01, 2007, 01:26 »
Only mono but this says it can do it Bob and its free :
http://www.sonicspot.com/2wav/2wav.html
« Reply #2 on: May 01, 2007, 16:57 »
Thats a dead link sandra. I tried cdmaster32 and it worked. You had suggested it to me on msn, but at first glance it looked like just a player. When i looked at the webpage i gave it another try and found some converting options.
I found out what makes the tracker files different. They aren't just one file. They're hundreds of little wav clips held together by this tracker format. I got a tracker player and loaded one of the files. When it plays it shows you scrolling text of what files are playing. Its kind of like a music box created with a spreadsheet.
« Reply #3 on: May 01, 2007, 19:19 »
Pleased you sorted it one way or another  :)
Its strange that link worked when I posted it this morning  :dunno:
