Author Topic: myphpadmin  (Read 1344 times)
myphpadmin
« on: June 02, 2007, 07:00 »
Does anyone know how to set myphpadmin and mysql to french characters so that i can have php output french characters instead of question marks?
Re: myphpadmin
« Reply #1 on: June 02, 2007, 08:57 »
oooh I've never come across that, english normally does the trick... is there a foriegn language package you need to install? dunno if this is useful... http://phpmyadmin.sourceforge.net/documentation/#faq5_11
Re: myphpadmin
« Reply #2 on: June 02, 2007, 09:47 »
One can change the charset of the database and the tables inside that database to different versions. I think i'm just off on how to set them. I had it set, accidentally, to a charset combination that worked for several days, but then it crapped out and started outputting question marks. I was hoping to find someone familiar with myphpadmin and fluent in french.
Re: myphpadmin
« Reply #3 on: June 02, 2007, 12:22 »
well i lose it on the last bit... sorry :-)
How come french btw?
Are you sure there isn't a combination of settings you have to use?
Re: myphpadmin
« Reply #4 on: June 02, 2007, 18:59 »
Why am I looking for a french phpadmin person or why am I using french on the database?
I setup the database with myphpadmin specifically to run a search engine I found for my server. It searches through all 30,000 files currently hosted on the server. The main issue i have with it is that some of the files have french characters in the name. So if I want the search engine to correctly list the url the database has to output the correct characterset.
There is a charset setting for communicating directly with mysql. There is a charset setting for creating a new database and there is a charset setting for creating tables. Each one lets you choose between about 30 different charsets. I've tried a ton of combinations.
« Last Edit: June 02, 2007, 19:02 by Bobscrachy »
Re: myphpadmin
« Reply #5 on: June 02, 2007, 21:16 »
either or really, I see now.
I had a play with some french files earlier on my ubuntu server and I kept getting some ??? everywhere, I did my normal thing... I'm English the french suck.. f*** it... :-D sorry I not of much use I know. It was odd how I just couldnt get it to work... I tried
this but still couldnt get it to work (thats an old post btw)
