Author Topic: Free anti virus for Vista?  (Read 1179 times)
Offline PhilTheFish
« on: June 04, 2007, 18:33 »
Hi all,
Just got myself a new laptop (cheapo for surfing on the sofa!). Tried to install my copy of McAfee on it only to find out it's not compatible with Vista.
Does anyone know of a free anti virus program that will work with Vista while I wait till I can pick a copy up from somewhere?
Cheers
Phil
Offline PhilTheFish
Re: Free anti virus for Vista?
« Reply #1 on: June 04, 2007, 18:38 »
It's ok....just realised AVG works with Vista.........download underway right now.
« Reply #2 on: June 04, 2007, 20:46 »
AVG definately works as I am using that with Vista at the moment  :)
« Reply #3 on: June 04, 2007, 21:12 »
McAfee???? Yuck. It would be a cold day in hell when i install an antivirus app that requires its own uninstall tool for removal.
FYI  Avast has a free vista version too, although i've never actually used it.
Download.com's list of freeware vista antivirus apps.
here
« Last Edit: June 04, 2007, 21:16 by Bobscrachy »
« Reply #4 on: June 04, 2007, 21:36 »
i also use avg on my parents vista system, seems to work quite well... not sure i know much about viruses in vista - sandra do you know how reliable these systems are?
« Reply #5 on: June 05, 2007, 00:22 »
I havent had one and I have been running Vista since december last year.
I havent noticed Vistas own inbuilt stuff pick anything up yet but AVG has stopped a couple of things so maybe thats the first line of defence and if I wasnt running it then Vista may have detected the same things and stopped them with bit defender or similar.
