Author Topic: mpeg4modifier  (Read 1728 times)
mpeg4modifier
« on: June 04, 2007, 20:26 »
howdy strangers
i know i haven't posted in a while so abject apologies all around.  Grovelling over, does anyone know how to use the above.  I want to unpack packed bitstream avi's with it.  I downloaded the software along with .net framework 1.1 which i believe is required to run it however i havent the vaguest idea what to do next.  The unzipped mp4modifier files don't contain an exe file  ??? :blush:
Re: mpeg4modifier
« Reply #1 on: June 04, 2007, 21:17 »
Post a link to its website please.
Re: mpeg4modifier
« Reply #2 on: June 04, 2007, 21:35 »
is this the tool you are referring to... http://www.moitah.net/
Re: mpeg4modifier
« Reply #3 on: June 05, 2007, 01:47 »
I have mpeg modifier Dave.  It installed ok on my pc.
http://www.free-codecs.com/download/MPEG4_Modifier.htm
I just open it and add avi file and click unpack then save the modified file.  Easy.  :)
Re: mpeg4modifier
« Reply #4 on: June 05, 2007, 07:57 »
yup that's the one Sam. Haven't a clue how to use it.  All i see are a couple of folders and some individual files, no exe file.  Thanks Lona I'll try your link.  Did you have to download netframework ??
Re: mpeg4modifier
« Reply #5 on: June 05, 2007, 08:09 »
i expect you should have an exe... redownload it - oh and yeah you will need to have the .NET Framework for it to work - I think you can get it from here
Re: mpeg4modifier
« Reply #6 on: June 05, 2007, 13:42 »
Ta sam, .NET framework already downloaded and installed. Definitely no executable file so i don't quite know how i'm supposed to run the program.  I'll post a list the files i unzipped from the mpeg4modiffier zip file when i get home tonight.  One thought, i d-loaded it to my old pc-still running on XP SP1, tho' i don't think not running SP2 should make any difference.  ???
Re: mpeg4modifier
« Reply #7 on: June 05, 2007, 19:11 »
Thanks Lona, that download did have an exe file  ;) however it didnt like my old .NET framework so i'll have to get version 2 and all should be well  :crazy:
Re: mpeg4modifier
« Reply #8 on: June 05, 2007, 19:53 »
Works fine on my XP SP2 machine, thanks guys n gals  ;D
Re: mpeg4modifier
« Reply #9 on: June 05, 2007, 19:58 »
It's a great wee programme, Dave.  I have to convert lots of movies that won't usually play on my standalone player. :)
