Author Topic: How can I format my HD ?  (Read 1282 times)
Offline TOFFEEMAN1878
« on: June 05, 2007, 18:02 »
If Windows can't complete it ,I want to replace XP Pro with Media Center .
Re: How can I format my HD ?
« Reply #1 on: June 05, 2007, 18:28 »
Restart the computer with your windows xp cd inside the tray. It will give you the option of formatting when you install.
« Reply #2 on: June 06, 2007, 00:58 »
You have to set the bios for the first boot device to be the CD though then do as Bob says  :)
« Last Edit: June 06, 2007, 00:59 by Sandra »
