Author Topic: Speed up Windows Vista  (Read 1245 times)
« on: June 10, 2007, 20:28 »
Windows Vista features what some think is the prettiest GUI in the OS industry. It's stylish transparencies and nifty animations?driven by Direct3D and your graphics card?give it a polished look that's a pleasure to use.
Unfortunately, that shiny, new interface, called Aero, is also a resource hog. If you're running Vista on a PC that's near or just above the system requirements, you might want to shut off some or all of those features.
Here are some actions you might want to take to tweak interface niceties:
http://www.extremetech.com/article2/0,1697,2110602,00.asp
Re: Speed up Windows Vista
« Reply #1 on: June 11, 2007, 18:46 »
« Reply #2 on: June 11, 2007, 22:12 »
Very cool, but I hate to think how much system resources that uses!
« Reply #3 on: June 11, 2007, 22:54 »
beryl... well it works on my old p4 with just half a gig of ram and a 32mb video card on it.. admittedly not at its best but it runs quite well...
