Author Topic: how to hide an ip?  (Read 2104 times)
Offline gunzzz5930
how to hide an ip?
« on: June 26, 2007, 23:26 »
can i hide my ip, so that i can download many times on rapidshare, and for other purposes... =)
Re: how to hide an ip?
« Reply #1 on: June 27, 2007, 00:23 »
I think that there are some programs that allow you to bypass the bit that recognises your IP on rapidshare if you Google for them.
Failing that, if you have a dynamic IP, then just logging off and back on again will change your IP address.
« Reply #2 on: June 27, 2007, 07:13 »
As well as what Sandra said, clearing your cookies when logging off and on again will also help.
« Reply #3 on: June 27, 2007, 07:42 »
I think you can get what is called a proxy server which means you are accessing websites via a third party and cannot be traced.  Whether or not they charge for the service I don't know.
« Reply #4 on: June 27, 2007, 10:49 »
I think anyone using cable broadband uses a proxy server Clive, I don't think it gives any degree of invisibility  :dunno:
« Reply #5 on: June 27, 2007, 13:57 »
Apparently Anonymizer is the answer according to a quick Google search.
http://en.wikipedia.org/wiki/Anonymizer
« Reply #6 on: June 30, 2007, 13:52 »
there is also something called the cloak.. but you really dont hide your ip address... well not to everyone anyway..
« Reply #7 on: June 30, 2007, 15:26 »
Besides, if you could hide your IP completely, most websites, including RapidShare, wouldn't work anyway.
Offline gunzzz5930
« Reply #8 on: July 15, 2007, 23:41 »
ahhh ic.. thank u. :D
