Author Topic: Free Online Virus Scanner & Removal  (Read 6193 times)
« on: July 20, 2007, 22:17 »
F-Secure Online Virus Scanner is a free service. Use it to find out if your computer is infected and disinfect your computer if needed.
The size of the download package is about 22 megabytes including databases.
http://support.f-secure.com/enu/home/ols.shtml
*Internet Explorer is required to use this utility*
Re: Free Online Virus Scanner & Removal
« Reply #1 on: July 20, 2007, 23:08 »
You can't put the cart before the horse Simon!   ;D
« Reply #2 on: July 20, 2007, 23:15 »
I know, it's the one flaw in the plan, Clive.  At least any viruses obtained when opening IE, should be found and dealt with by the free scan!  :o:
