Author Topic: Connecting to internet after sleep mode.  (Read 1173 times)
Offline castro
« on: July 24, 2007, 13:48 »
I have a good wireless connection to my laptop. If I close the lid and go into "sleep mode" then reconnect, the connection to the router is ok but I cannot browse the internet. This does not happen every time. When it does happen, I have to reboot to get a connection.  The router shows that the laptop is connected. My pc, connected to the same router works ok so it's not the router.
Any ideas please.
Re: Connecting to internet after sleep mode.
« Reply #1 on: July 24, 2007, 20:35 »
There will be some other suggestions, Castro, but the only thing I can think of at the moment is that it could be something to do with a software firewall.  Do you have one on the laptop?  I'm just thinking, maybe the firewall is not 'waking up' fully from sleep mode for some reason, and therefore your internet connection is blocked?  Next time it happens, try restarting the firewall, and see if it has any effect, if only to eliminate that as a possible cause.
Offline castro
« Reply #2 on: July 25, 2007, 08:28 »
Hi Simon.
Thanks for reply.
I think that I will have to disable the software firewall in order to check out this solution.
Do you know how effective the router is as a firewall?
Will the inbuilt windows firewall, which is presently disabled, be ok to use in the short term?
« Reply #3 on: July 25, 2007, 08:57 »
The router firewall should be safe to rely on for a short period of testing.  In fact, some people rely on their router firewalls entirely, and don't use a software firewall, but personally, I prefer the safety blanket of both.  Just test it with a safe website (such as here), and you should be fine, or, as you mentioned, use Windows Firewall temporarily if you are particularly concerned.
Offline castro
« Reply #4 on: July 25, 2007, 14:10 »
Thanks simon.
I will give it a try and report back in a few days.
Offline DJ
« Reply #5 on: July 26, 2007, 19:14 »
My laptop (an IBM / Lenovo) does this too!
Only way I fix it is to switch off the wireless (Fn + F5) then switch it on again.  Only takes a few seconds.
Cheers, DJ.
