November 27, 2024, 20:53
Technical Help & Discussion
General Tech Discussion, News & Q&A
Start menu locked?
Topic: Start menu locked? (Read 2483 times)
welshy.
Regular Member
Start menu locked?
July 27, 2007, 18:09 »
Hiii, more then likely a simple answer to this lol, my start menu seems to be locked? I can't right click it, go to properties or pin to etc.. Kinda annoying me, it happened before and i never solved it. Thx in advance.
Sandra
Ultimate Member
Re: Start menu locked?
July 27, 2007, 18:36 »
Cant think whats caused it but can you use the Windows key to open the start menu ?
Or do you mean you can open it but not do anything after that ?
July 27, 2007, 20:08 »
or you mean you can't edit it?
welshy.
Regular Member
July 27, 2007, 20:36 »
Sorry
I meant it pop's up but i can't do nothing with, edit etc
July 27, 2007, 20:48 »
That sounds odd. Can you tell us what you want to do with it?
welshy.
Regular Member
July 27, 2007, 21:01 »
Pin stuff to it for one
July 27, 2007, 21:08 »
so what happens if you right click on one of the icons in it?
are you using xp?
welshy.
Regular Member
July 27, 2007, 21:11 »
Quote from: sam on July 27, 2007, 21:08
are you using xp?
Absolutely nothing happens, yup XP, i can't even drag the icons
July 27, 2007, 22:37 »
OK, try this - Right click the Start button > Properties > Customize > Advanced (tab), then check that "Enable dragging and dropping" is ticked.
welshy.
Regular Member
Reply #9 on:
July 27, 2007, 23:05 »
lol awesome that sorted it! no idea how it got unticked though? I'd imagine remembering doing such a process.
Reply #10 on:
July 27, 2007, 23:10 »
Glad it's sorted! If it happens again, it might be worth checking for viruses / spyware, unless someone else has access to the PC, and could have been fiddling about.
Reply #11 on:
July 27, 2007, 23:27 »
... which includes fidling by accident I guess...
welshy.
Regular Member
Reply #12 on:
July 28, 2007, 05:09 »
I don't fiddle
if it ain't broke, don't fix it
Start menu locked?
