Author Topic: downloading tv guide in media center  (Read 1276 times)
Offline chelseamick
« on: August 05, 2007, 19:19 »
I have a three month old computer running vista and am having trouble doanloading the tv guidethats within windows media center I'm getting an error message "Guide server error. File validation error mismatched guide package code 21"
Has anybody any idea what this means? I've tried contacting the dealer I purchased it from and I'm getting nowhere.
many thanks for any help I recive.
Re: downloading tv guide in media center
« Reply #1 on: August 06, 2007, 00:21 »
I dont know that particular code but it sounds like a firewall problem.
Mine didnt need anything doing to it to allow it to download and it always connects ok.
Have you got a 3rd party firewall on that you can temporarily disable to see if it works ok ?
Offline chelseamick
« Reply #2 on: August 06, 2007, 13:38 »
Thanks for your reply Sandra,  the only firewall i'm using is the one in vista.  I tried switching off that and downloading the guide but it still didn't work.  For the first 2 months everthing worked great but for the past month it's been duff.
on 6/7/07 i recieved an update for media center and although I'm not sure exactly it was about that time when I started having trouble, it may have been a coincidense
Offline chelseamick
« Reply #3 on: November 01, 2007, 09:31 »
After many months of searching for an answer to my problem ie error 21 when downloading the guide in microsoft media center I discovered that I could download the media epg by switching off the administator controls, as I am the only user of the pc I don't need it anyway, it now works a treat.  I hope this helps others with this problem
« Reply #4 on: November 01, 2007, 09:41 »
Thanks for the update, Mick.   :)
