Author Topic: updates  (Read 1070 times)
Offline Baz
updates
« on: August 10, 2007, 14:46 »
didnt know where to put this one
is it possible to get windoze updates while using firefox?
I keep getting the message  "you must be using Internet Explorer......blah de blah!!!!"
Online Simon
Re: updates
« Reply #1 on: August 10, 2007, 14:55 »
I don't think it's possible to download them manually, but you can set Windows Update to download automatically.  Go to Control Panel > Security Center, make sure Windows Updates is On, then click the Windows Updates link at the bottom, after which a new window should open.  Select the Automatic option, and that should do it.
Alternatively, you could try the IE View add-on for Firefox, which enables you to right click any webpage, and view it in IE.  Much as it says on the tin, really.
Offline Baz
Re: updates
« Reply #2 on: August 10, 2007, 16:42 »
cheers Simon,
not sure about this automagically stuff with windoze stuff..........but thats just me ;D ;D
Online Simon
Re: updates
« Reply #3 on: August 10, 2007, 17:45 »
I agree to a point about automatic updates, but M$ will force them on you sooner or later, so my theory is that if they are downloaded automatically, it saves a huge update at a later stage.  They are mostly security fixes, and I would rather have these, than possibly put my PC at risk by not having them.  All in all, M$ updates are usually relatively harmless.
Re: updates
« Reply #4 on: August 10, 2007, 18:12 »
