Author Topic: Firefox 3 Takes Web Animation to the Bleeding Edge  (Read 1281 times)
« on: August 16, 2007, 11:30 »
Re: Firefox 3 Takes Web Animation to the Bleeding Edge
« Reply #1 on: August 16, 2007, 12:32 »
Firefox 3 looks interesting, but it should be noted that it's the Beta version that will be available for download in a few weeks.
« Reply #2 on: August 16, 2007, 12:42 »
I've never understood what a beta version means, Michael said something about them being experimental versions.  :dunno:
« Reply #3 on: August 16, 2007, 13:51 »
Yes, exactly.  Like Windows XP.  ;D
« Reply #4 on: August 16, 2007, 13:56 »
basically you have alpha (software developers only really), beta (which is a wider community one) and then release candidates which end up with  the final product...
Si, the first version of XP must have been an alpha  :devil:
« Reply #5 on: August 16, 2007, 14:24 »
Oh, okay thanks Sam.
So what do you call Vista then?
« Reply #6 on: August 16, 2007, 15:17 »
Sh1t.
« Reply #7 on: August 16, 2007, 16:08 »
« Reply #8 on: August 16, 2007, 18:35 »
