Author Topic: Budget laptop  (Read 3587 times)
Budget laptop
« on: August 17, 2007, 14:32 »
A friend has asked me to have a look for a laptop, for around £350, and I came across this one, which looks OK to me, but as I don't have a clue about laptops, could someone give it the once over for me?  Also, do they all come with 56K modems, or do they all not now, assuming everyone has broadband?
Oh, and if anyone can find a better deal, please let me know!  Windows XP would be a preferred option.
TIA  ;)
Re: Budget laptop
« Reply #1 on: August 17, 2007, 17:20 »
it seems good, looks similar to a friend of mines (not the same but his is pretty ergonomic) - Acer make some good laptops. Will they use it as a laptop or a desktop replacement.. thinking weight issues - worth considering (it says light but I can't actually see a value!)
Re: Budget laptop
« Reply #2 on: August 17, 2007, 18:28 »
I think it will be a desktop replacement, so it will mostly be used on a desk.
« Last Edit: August 18, 2007, 00:01 by Lona »
Re: Budget laptop
« Reply #4 on: August 18, 2007, 00:11 »
Thanks Lona, that one looks good also, but I think there's a definite budget of £350 to be adhered to.  I'm actually tempted by one of these myself, but I've spent quite a bit already this month, so it will have to wait a while.  Apart from the screen size, how much better is the one at PC World to the one in my link?
Re: Budget laptop
« Reply #5 on: August 18, 2007, 00:32 »
the problem is it is an advent.. they always use cheap components... well from my experience and what I have heard..
Re: Budget laptop
« Reply #6 on: August 18, 2007, 04:58 »
The specs look good to me clive. It's already obsolete. But if your friend just needs it for actual work and not game play then go for it. I have my doubts about that 1yr warranty though. It's not like you can easily just pop the case on a laptop. Thats why I use to always tell my customers to get at least a 3 year. Laptops get expensive when they need repairs.
Re: Budget laptop
« Reply #7 on: August 18, 2007, 09:57 »
Which one are you referring to, Bob?  All consumer electronics carry a 1 year manufactures warranty, when purchased new.  I guess, if it went wrong within the year, the retailer would replace it and throw it back at the manufacturer, rather than attempting to repair it, unless it's something simple.
Re: Budget laptop
« Reply #8 on: August 18, 2007, 18:18 »
I was talking about the one you asked about to begin with. The other was out of your friends price range right? Over here department stores tend to sell things, advertised, with a three year warranty. Normally its 1 year with the store and an added 2 with the manufacture. What i was saying was I wouldn't buy one without a 3 year warranty.
Re: Budget laptop
« Reply #9 on: August 18, 2007, 19:25 »
Oh, I get you now.  I expect an extended warranty would be available somewhere, but having discovered a little more about the 6 year thing mentioned in this thread, I'm starting to wonder if a warranty means anything!
Re: Budget laptop
« Reply #10 on: August 18, 2007, 19:27 »
I wouldn't be surprised if they made you sign a waver at purchase having you relinquish your warranty rights in fine print.
Re: Budget laptop
« Reply #11 on: August 18, 2007, 20:26 »
Well, I've no doubt they would find some way out of it.
Re: Budget laptop
« Reply #12 on: August 18, 2007, 23:20 »
TIA  ;)
if it was me, I'd go for one with a built in webcam like the Acer 5103WLMI
Acer 5103WLMI
Acer built in webcam
« Last Edit: August 18, 2007, 23:26 by Tony »
Re: Budget laptop
« Reply #13 on: August 18, 2007, 23:37 »
All they want it for is basic surfing, email and office tasks, Tony.  A webcam would just complicate things.   :o:
Oh, and about TinyURLs?  Yeah, we use a spam blacklist mod, and for some reason, TinyURL is on it.  I could remove it, but I think it would only be temporary, as the database is automatically updated, so it would probably reappear again.  I'll check it out with Sam.  Alternatively, a Link type link could always be used to save long URLs, but it doesn't really matter, as the software creates a horizontal scroll bar, so as not to distort the page.
Edit:  Like you did while I was typing this!
Offline jww41005
Re: Budget laptop
« Reply #14 on: August 22, 2007, 15:54 »
Here in Spain there's a big department store chain called 'el corte inglés' that promotes quite a lot of equipment from Acer.
El corte inglés is a high quality shop so, if they sell it, it must be alright.
John
If it works, don't fix it
