Author Topic: Another AVG Question  (Read 995 times)
« on: August 20, 2007, 13:11 »
Does anybody know if there is a registry "hack" which can be used to alter how often AVG Free Edition demands to be updated?
I spend a lot less time on the computer than I used to, especially during "summer" when I am often out hiking or camping.  As a result, the computer can sometimes go days at a time without being switched on.  AVG Free demands a update every five days and there is no way within the program to change this, so (at the moment) every other time I switch the thing on I get AVG demanding an update.  For example, I have switched on today, got the pesky "Definitions are out of date" bubble, updated the definitions, then had to update the program as the update manager was indicating that a program update was ready, updated that and then immediately after restart another update was waiting.  By the time I had done all of this and then allowed the changed program in my firewall, seven minutes had gone by and I had only put the PC on to check for an email I am expecting from a campsite owner!  This is unacceptable.
There must be something in the registry that can be altered to force AVG to look for updates at a more reasonable interval, like every fourteen days.  If anybody can tell me where it is I'll put you on my Christmas card list!
Thanks.
Re: Another AVG Question
« Reply #1 on: August 20, 2007, 14:01 »
is that problem with the bubble more related to windows detecting that it is out of date than avg?
« Reply #2 on: August 20, 2007, 16:26 »
Dave, have you tried unticking both boxes in the >Test Centre > Scheduler >  Edit Schedule tab. And just doing it  manually by hand when the fancy takes you ;D
« Reply #3 on: August 21, 2007, 09:11 »
Thanks, Tony, I'll try that.   :)
The bubble seems to be built in to AVG, Sam, but I have found a way to turn the alerts off.
Thanks again.
« Reply #4 on: August 22, 2007, 08:53 »
Disable it in startup and setup the windows scheduling agent to execute it once a month or whenever you there. That would be a little more automated. The lazzzzy way. It takes too much effort to press that update button.  ;)
