Author Topic: Google search  (Read 1517 times)
Offline Camstop
Google search
« on: March 04, 2003, 21:52 »
To get google instead of crappy msn search when you hit your search button look here.
It's dead easy... ;)
Re:Google search
« Reply #1 on: March 04, 2003, 22:23 »
That's very handy to know, Cam!   :)
I use a slightly different approach which avoids the need to click that search button altogether.  I've created a sub-directory within my Favorites folder, called 'Search' and plonked the links to every search engine of any merit, in there.  There are 16 of the little devils right now, but I usually still end up using Google anyway.   ::)
Offline bat69
Re:Google search
« Reply #2 on: March 09, 2003, 22:14 »
Thanks Camstop ... Google nicely installed as default now ... cos I'm lazy and its easy to hit the button  :heehee:
Re:Google search
« Reply #3 on: March 09, 2003, 22:19 »
You shold all use Opera ;)
All the search engines are available on the standard toolbar ::)
