Author Topic: Windows XP  (Read 945 times)
Offline dcourtneym
Windows XP
« on: September 05, 2007, 18:26 »
I may have to buy a new computer in the near future and I am wondering if it would be possible to transfer all my data and O/S to a portable hard drive, format the hard drive on the new computer. I am used to XP and some of my peripherals aren't suitable for Vista.
I am not skilled enough to use Linux.
Any comments welcome.
Re: Windows XP
« Reply #1 on: September 05, 2007, 18:42 »
You can still buy machines with XP pre-installed.  Dell do them due to consumer pressure.  I don't think you can just transfer lock stock and barrel like you suggested.  You can certainly use that method for transferring data, but most of your programs would need to be reinstalled on the new machine.
Re: Windows XP
« Reply #2 on: September 05, 2007, 21:07 »
this might help with your problem first you would need some type of os on the new computer
i used it when i added a new hard drive and wanted it for a main drive
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD
