Author Topic: Airplane faults  (Read 526 times)
Airplane faults
« on: September 06, 2007, 15:12 »
Remember, it takes a college degree to get to fly a plane but only a high
school diploma to fix one.
 After every flight, Qantas pilots fill out a form, called a "Gripe Sheet"
 which tells mechanics about problems with the aircraft.
 The mechanics correct the problems; document their repairs on the form,
 and then pilots review the Gripe Sheets before the next flight.
 Never let it be said that ground crews lack a sense of humour. Here are
 some actual maintenance complaints submitted by the pilots (marked with a
 P) and the solutions recorded (marked with an S) by maintenance engineers.
 By the way, Qantas is the only major airline that has never, ever, had an
 accident.
 P: Left inside main tire almost needs replacement.
 S: Almost replaced left inside main tire.
 P: Test flight OK, except auto-land very rough.
 S: Auto-land not installed on this aircraft.
 P: Something loose in cockpit.
 S: Something tightened in cockpit.
 P: Dead bugs on windshield.
 S: Live bugs on back-order.
 P: Autopilot in altitude-hold mode produces a 200 feet per minute Descent.
 S: Cannot reproduce problem on ground.
 P: Evidence of leak on right main landing gear.
 S: Evidence removed.
 P: DME volume unbelievably loud.
 S: DME volume set to more believable level.
 P: Friction locks cause throttle levers to stick.
 S: That's what friction locks are for.
 P: IFF inoperative in OFF mode.
 S: IFF always inoperative in OFF mode.
 P: Suspected crack in windshield.
 S: Suspect you're right.
 P: Number 3 engine missing.
 S: Engine found on right wing after brief search.
 P: Aircraft handles funny...........
 S: Aircraft warned to straighten up, fly right, and be serious.
 P: Target radar hums.
 S: Reprogrammed target radar with lyrics.
 P: Mouse in cockpit.
 S: Cat installed.
 P: Noise coming from under instrument panel. Sounds like a midget pounding on something
     with a hammer.
 S: Took hammer away from midget.
