Author Topic: How to keep numlock enabled on boot  (Read 2088 times)
Offline Michelle
    • Techieminx
« on: September 13, 2007, 17:58 »
My boyfriend's new laptop (second hand) doesn't start up with numlock enabled as he would like it.
I've had a look on line, and it seems it need to be changed in the registry - I don't really like to do this, so does anyone know of another way?
thankee in advance
xx
Re: How to keep numlock enabled on boot
« Reply #1 on: September 13, 2007, 18:17 »
Maybe a dumb question, Michelle, but does he have a numeric keypad - most lappies don't?
« Reply #2 on: September 13, 2007, 19:39 »
Is there an option in Control Panel/Regional-Language Options/keyboard & Languages.
Offline Baz
« Reply #3 on: September 13, 2007, 21:00 »
dont know about lappys but isnt it usually in the bios set up?
Offline Michelle
    • Techieminx
« Reply #4 on: September 13, 2007, 22:09 »
not sure if in bios - yes it is numeric keypad
I'll look for that TR
thanks
« Reply #5 on: September 14, 2007, 00:57 »
This should do the job for you, Michelle.
http://support.microsoft.com/kb/314879
Offline Michelle
    • Techieminx
« Reply #6 on: September 14, 2007, 16:13 »
ah, thanks alot Rik
