Author Topic: SuperAntiSpyware log entry  (Read 1163 times)
Offline Argee
« on: September 19, 2007, 12:08 »
Over the last few days, I've noticed when firing up (XP Pro, SP2+updates) that the Spyware resident shield pops up a notice regarding an allowed registry change. When I look in the log, it states:
19/09/2007 11:51:03 Allowed value "scrnsave.exe" (new data: "C:\WINDOWS\system32\logon.scr") changed in Desktop settings!
What is going on, any ideas, please? Is this a sign of malicious activity?
Ray.
Re: SuperAntiSpyware log entry
« Reply #1 on: September 19, 2007, 12:46 »
I would hazard a guess that "scrnsave.exe" is indeed your Windows screensaver, and unless you have downloaded any other screen savers off the web, I would presume it to be harmless, but best to do a full virus / spyware scan to be on the safe side.  It could be a false positive from SAS following an update, which will hopefully disappear with the next update.
« Reply #2 on: September 19, 2007, 15:26 »
go here and check they keep an archive of virus and spyware
bleeping computer .com
it is a clean site and signup is free
http://www.bleepingcomputer.com/forums/index.php?http://www.bleepingcomputer.com/
Offline Argee
« Reply #3 on: September 19, 2007, 19:19 »
Thanks for the help - much appreciated. :)
Ray.
